Gday Just reading the answers for water in fuel and adding metho. ummmm soooo have got this right I have read that getting some water into the engine can decarbonise it if done correctly and is healthy to do so. So can you add water and Metho to the fuel deliberatly to achieve the same results or have i misunderstod your answer. Thanks
Hi sandman 308.
I don't think adding water to the fuel tabnk deliberately is a very good idea.
To get the effect you want, use a cheap water injection kit.
Another alternative is to do the old 20 cent tune-up. We used to remove the air cleaner, w |
