Hi,
Mate of mine here at work needs to pick up a new sump bolt for his 186 today for a safety inspection, but forgot to bring one in from home.
Does anyone know off the top of their head the actual size, so he can pick one up?
Much appreciated if anyone knows...
Cheers, Jason.
i think they are 1/4 UNC by 12 mm long but the ones that are at the front are differant longer i think
Hi Guys.
I don't think Jason is referring to the bolts that hold the sump to the block, they're 1/4" UNC.
I think he means the drain plug, which I think is 1/2" UNF. I will double check that today.
Dr Terry. |
Thanks guys - once again Fastlane comes up with the goods. :-)
Much appreciated.
Jason.
