Vintage Caravans Offline
#1 Posted : Sunday, 7 August 2005 9:45:25 PM(UTC)
Vintage Caravans
Reading through several old posts, I have noticed that there appears to be a way to identify what the trimatic came out of??
I have a trimatic in the car and was wondering what it came out of, it has a 360 degree bellhousing and shift on the right hand side, so I have been told it is WB commercial??
Anyway if someone can id it I would be gratefull!
Plate on LHS reads
F gmh B
Cat = A
then serial number = 0673250
thanks
Matt
1962 EK Wagon - Chev SBC & T700, 1962 EK Sedan - Chev SBC & T700,EK Ute - V6 Buick & 5 speed = LOOKING FOR A 1962 EK VAN
#2 Posted : Monday, 8 August 2005 10:21:22 PM(UTC)
It could also be an early box with the commodore bellhousing bolted on
#3 Posted : Tuesday, 9 August 2005 6:22:40 AM(UTC)
Hi Guys.
The FB code Tri-Matic was fitted to late HZ 202 (3.3). It ha a 'full-circle bellhousing like a Commodore but has the RH shift.
It was used in all HZs except the 1 tonner with the 4.44 diff ratio (different speedo drive gear)
Dr Terry.
#4 Posted : Tuesday, 9 August 2005 3:45:09 PM(UTC)
Vintage Caravans
Thanks for that Dr Terry, exactly what I needed to know
Matt
