Can anyone tell me what the power output is from a 350 injected motor from an 86 Corvette.
Thanks: 1 times Was thanked: 635 time(s) in 597 post(s)
I think the TPI 350 from that era was rated at 350hp. Thee was also a 390hp version called a ZZ3? or something like that but I don't think it was from the Corvette range. |
Thanks Byron. I don't think it was quite that high but at least I have a ball park figure to work on.
Andrew
86 model corvette had a base model 350 rated at 230 hp
Thanks Bratt. That's more like the figure I thought
BluHJ
Hi Guys
With advertised hp figures you have to be careful of 'net' figures & 'gross' figures.
Manufacturers used both during the '70s & '80s & you can't compare apples with oranges.
Dr Terry. |
