I have a HZ Sandman van, im fitting the injection from a VP Commodore, But im having trouble getting info on 5 speeds boxes i can use so i can keep the factory centre console. T5 is good but im told its too long, then T5 from a falcon as its shorter, then go for a tremic? With the bonnett closed i want it still looking factory. thanks for your help..... Mikey
Thanks: 1 times Was thanked: 636 time(s) in 598 post(s)
A Supra will probably be your best shot, and probably cheapest. Try Dellow or CRS for info. |
