has anybody used the pennzoil range of oils?? if so what is your opinions of them
You are a member of these groups:: Registered, Veteran
i run it in all my cars,2 of which ive owned for 8 years...personally find it very good.. |
I always use Pennzoil, even in the mower...
Kevin
HOLDEN The Great Way to Move |
I use Penzoil HRP50 in the 308 and sware by it
Top oil. Penzoil or Penrite are the best Oil for the $$$ Dont use anything less. anything better is good if you can afford it
DO NOT WRITE BELOW THIS LINE
