YetAnotherForum.NET Help
#1 Posted : Tuesday, 11 October 2005 1:12:59 AM(UTC)
This may sound a little silly, but where are the thermostats on these guys? There doesnt seem to be a housing anywhere for them? Some help would be appreciated
Intoit Offline
#2 Posted : Tuesday, 11 October 2005 2:30:12 AM(UTC)
Intoit
Steve ,
I have a friend with a Barina . She put it in for a service & they told her it needed a new thermostat . She was a bit worried that she was being ripped off so I went & seen the mechanic for her . He showed me where the thermostat was . If you lo
--------------------Go Hard Or Go Home
#3 Posted : Tuesday, 11 October 2005 3:27:34 AM(UTC)
Thanks for that, helped a heap, its a bit camouflaged in amongst all that stuff. Cheers
#4 Posted : Saturday, 29 March 2008 1:29:48 AM(UTC)
This is true. I just changed the head gasket, and checked the thermosstat at the same time. Yes the timing has to be removed. its not as dificult as it looks but if you do stuff it up it is costly.
