hello all, just a question about 186 numbers i have numbers stamped 186P then the engine number i've been told this is a ht/g/k version of the hp 186 engine is this true?
Thanks: 1 times Was thanked: 636 time(s) in 598 post(s)
No. It's simply a HK/T/G 186. Nothing special. Just a cast iron crank 186. The 186S is the performance version of the 186 in the HK-HG range. There is no such thing as a 186HP, unless you count an EH 179 bored +0.060" as a 186HP, but even then it's no dif |
