Sandman Offline
#1 Posted : Saturday, 22 October 2005 12:59:19 AM(UTC)
Sandman
I've got a VX Berlina V8 wagon with auto. I just use it for traveling when i go away. I'm looking for any mods that will increase fuel economy, (preferably with an increase in HP as well)
It's got triY extractors, dual system with a balance pipe. I put an SS airbox on and it went from 11.2lts/100km to 10.6lts/100km.
The best I've had it is 9.5lts/100km, at 110kph with the A/C off.
I was thinking of some 1.85 rockers, anyone tried them??
Eventually I'll get the computor redone,but I want to get mechanicals mods sorted first.
I don't want to start changing anything inside the engine, cam, heads etc. As I want to keep this as a reasonably? standard car, I've got other hot chevs in HQ's to go and thrash if I want to go real quick.
Do they have speed limiters programmed in? This won't go past 220.
Any info and feedback on all this will be greatly appreciated
#2 Posted : Saturday, 22 October 2005 4:38:52 AM(UTC)
You'll probably get the answers to all your questions, and more, on LS1.com.au
Get an HSV Clubsport R8 (285 kw) tune put in your computer. It will cost about $200 and it will be the best $200 you can spend on your car. When I had mine done, I gained ab
#3 Posted : Monday, 24 October 2005 6:11:00 AM(UTC)
have you changed the filter to a high flow yet?
you have pretty much covered the main mods so far, so go get a "Custom" tune.
i dont agree with Qute, as it still may not be 100% suited to your setup.
if you get it done on a dyno, realtime, with LS1edit
This page was generated in 0.473 seconds.
