gidday guys' what precautions, tips should i do before i crank over a fully rebuit 308 motor
the more the better....thanks
Thanks: 1 times Was thanked: 636 time(s) in 598 post(s)
Make sure the oil pump is primed (normally full of grease or vaseline). Also make sure the lifter bases and cam is covered in cam lube. Crank it over with the coil lead removed until it gets oil pressure, then start it and run it for 20 minutes at around |
Tim,
Byron is correct here is a bit more.
(1) When its a "never been fired up" donk there is no oil in the lines/journals. Per Byron. Nor is there oil at the rings ! My Dad always told me to put/squirt a small amount of engine all into each cylinde
Use non-friction modified oil for the first 10,000 k's. The friction modifiers will greatly hinder the bedding in of your motor's internals. I agree with John and Byron's advice above, except I usually change oil and filter at 100 k's, then oil at 500 Edited by user Wednesday, 26 October 2005 8:19:35 AM(UTC)
| Reason: Not specified
All of the above.... Squirt oil all over the valve gear as well before fitting the tappet covers. We use a rattle gun at work to turn the engine over until oil pressure is obtained, before starting. |
In thrust we trust |
guy's thanks heaps, all of these tips, are very basic and helpfull. as you all know with cars nothing is cheap. And especially when you put in the unpaid time, cost of parts and labour, these simple tips help in the long run
thanks again
quote: Originally posted by Qute
Use non-friction modified oil for the first 10,000 k's. The friction modifiers will greatly h |
___________________ - HJ turbotonner looks and goes like a sneezing rhino on heat! - |
Not sure on the non-friction modified additive. Usually the older specification and/or cheaper oils are non-friction modified. They are getting harder to find these days.
If you use friction modified oil early in a motor's life, the teflon in it coats
I should have added that the Friction Modifiers are an additive to the oil in the first place...
Cheers...Dave
You have to be careful about what oil is and is not friction modified. I once put an oil into my motorbike that didn't mention friction modifiers but the result was a badly slipping clutch caused by the friction modifiers. A couple of oil changes later us |
Hence my comment from early on !!
NOTE: Teflon stuff is fine for cams, and lifters..but not for the rings !!!! OK ?
John
