#1 Posted : Sunday, 6 November 2005 7:39:03 AM(UTC)
hi i need help with a part i have but i dont know what its for i came with a wb statesman im sorry but i couldnt put a pic up so i thought maybe someone here may know the code if not i'll try the pic again,thanks.ok its in a original gm packet and it says GENERAL MOTORS CORPORATION DETROIT MICHIGAN the number is 1#6261784 then it has in smaller print 78F9 GR.4.343 GEAR .i think its a gearbox speedo drive but im not sure its nearly 5 cm across and the hole in the middle is quite large its over 3cm round.any help is realy helpful,if it is a gearbox spedo drive what g/box does it fit???thanks
Munromad2004 Offline
#2 Posted : Sunday, 6 November 2005 11:08:06 AM(UTC)
Munromad2004
This is a drive gear (on gear box drive shaft) from a Turbo 350 auto transmission as fitted to HZ/WB's
All I did is google your number (6261784) and this page came up. http://oldholden.com/?q=node/3903
It lists all speedo drive/driven gears for Hol
#3 Posted : Sunday, 6 November 2005 7:39:26 PM(UTC)
thanks heaps your a great help :)
