lonemonaro Offline
#1 Posted : Saturday, 19 November 2005 11:28:15 AM(UTC)
lonemonaro
Hi all,
What is the safest and most responsible way of removing an airconditioner from a car. It is an underdash model and I need to safely remove it and store it later on for my Monaro.
What considerations do I need to take into account for it's safe removal and storage.
Kind regards
George
Edited by user Saturday, 19 November 2005 11:29:39 AM(UTC)  | Reason: Not specified
#2 Posted : Saturday, 19 November 2005 11:36:22 AM(UTC)
It is illegal to just unscrew the aircon. Take it to a dealer they can do it safely and tell you how to store the unit. Basically keep the ends sealed air tight. There are big fines for letting the gas out and it is dangerous it can burn your skin right o
lonemonaro Offline
#3 Posted : Saturday, 19 November 2005 11:54:05 AM(UTC)
lonemonaro
Hi John,
Thank you for your sound advice, as I was unaware that it's illegal to unscrew the airconditioner. Better to get an airconditioner expert to undertake the necessary, whilst keeping within the restrictions and guidelines of the EPA.
Actuall
Dylan Offline
#4 Posted : Saturday, 19 November 2005 9:36:51 PM(UTC)
Dylan
i dont know about cars, but when we charge aircon systems on buses we fill them with nitrogen to absorb all the mositure in the system and check for leaks, so as long as the ends of the lines are taped up to stop dust getting in it shouldnt be a problem.
#5 Posted : Sunday, 20 November 2005 10:59:00 AM(UTC)
I probably should make it clear the stuff burns the skin because it is well below freezing point, it is the cold that burns, not the gas itself.
#6 Posted : Sunday, 4 December 2005 11:35:23 PM(UTC)
YOU NEED TO GET SOMEONE WITH A RECLAIM UNIT, they will suck all the refrigerant out of the system and store it in a gas bottle. Whether you choose to seal the pipes with tape, or plug the evaporator with nitrogen is up to you. It is a good idea to plug an
