#1 Posted : Saturday, 26 November 2005 3:50:11 AM(UTC)
Hi guys - just wondering if anyone knows the length needed for the power steering hose in a red 6 - have to get one made up.
#2 Posted : Saturday, 26 November 2005 4:06:34 AM(UTC)
Hi Spud.
A little more info would help.
Model EH, HK, HQ, VB ??
What pump mount ??
What steering set-up ??
High Pressure or low pressure hose
Dr Terry.
#3 Posted : Saturday, 26 November 2005 4:16:45 AM(UTC)
Thanks Terry - the car's a HX, the box is the Bendix Bishop unit, the mount is the one from the picture posted here not long ago showing the assembly and the pump looks to be a standard hq-wb item.
The high pressure hose is the one im after. Is it oka
Edited by user Saturday, 26 November 2005 4:22:56 AM(UTC)  | Reason: Not specified
#4 Posted : Saturday, 26 November 2005 5:47:46 AM(UTC)
Hi Spud,
Why do you have to get one made up? They are still available new and are the same as the V8 version...
Cheers...Dave
#5 Posted : Saturday, 26 November 2005 6:10:07 AM(UTC)
I've got the V8 one; I just read on here that they're different lengths.
Hmmm...
I'll bang it all in and take measurements. I can ride the bike to a hose place.
Cheers guys.
#6 Posted : Saturday, 26 November 2005 9:34:04 AM(UTC)
My HX Part Manual says the only Pressure Hose available is Part Number 2825687 and fits all models. If the 6 was different to the 8, they would be listed as separate items.
When I put power steering in the Qute (202), I used a complete V8 setup (change
#7 Posted : Saturday, 26 November 2005 9:49:04 AM(UTC)
Thanks Qute. I'll just use the on in the box. Cheers!
#8 Posted : Saturday, 26 November 2005 10:12:45 AM(UTC)
Just check that the pump end of the hose is compatible with the pump. There are two types: one has an O-ring and the other seals with a tapered olive style fitting. For the return line use transmission fluid hose.
#9 Posted : Sunday, 27 November 2005 9:40:08 AM(UTC)
Mine's got the tapered syle fittings and it seems to match the pump perfectly. Good point though Rich.
You guys get a lot of power steer questions? Do you have a FAQ sheet on the topic specifically?
#10 Posted : Sunday, 27 November 2005 9:55:18 AM(UTC)
We get a few power steer questions....once you know the couple of variables (and there are only a couple), the rest is all the same.
Cheers...Dave
one tonner man Offline
#11 Posted : Saturday, 21 January 2006 12:33:31 PM(UTC)
one tonner man
The L6 and 253&308 V8 hoses are all the same length in a HQ to HZ and more then liky in a WB too. Tho I think the 350 V8 power steering hose are longer. As the hose runs from the steering box along the stabiliser bar to the pump witch is on the other side
If I agreed with you we`d both be wrong.
