hey all will a wb front door fit on a hj stato
Front doors are interchangeable between all models and body styles from HQ through to WB, except the coupes. Late HZ and WB doors have anti-intrusion bars in them and are much heavier than the early doors, but will still fit earlier models. utes vans and
Thanks: 1 times Was thanked: 636 time(s) in 598 post(s)
AFAIK all HZ's and late HX's had the intrusion bars (but not commercials). I believe late LX Torana and HX coupes had the intrusion bars too. |
byron is correct...all commercials had no intrusion bar,was not adr requirement even on taragos etc until late 80s early 90s...hx coupe and lx did have intrusion bars ... |
That's three of us now that said no intrusion bars in commercials!...LOL
My point was the intrusion bars started way earlier than late HZ, in HX/LX in fact. Edited by user Sunday, 4 December 2005 12:13:31 AM(UTC)
| Reason: Not specified |
What about the differences in the window shape?
The HQ doors have a different front corner to later ones that have a small infill panel in the bottom corner of the triangle, and the glass is different.
I dunno when the changeover was, but I found |
I have a first run 74 HJ Coupe (10/74) and it has intrusion bars. Cheers, Pete. Old Holdens never die, they just go faster. Edited by user Sunday, 4 December 2005 10:04:53 AM(UTC)
Cheers, Pete. Old Holdens never die, they just go faster. |
Hi Mick,
AFAIK, the change-over in the windows was the change from HQ - HJ. HJ - WB front door glass (except coupes) are all the same.
The infill panel was supposed to stop the window glass being "sucked out" when it was opened a small amount and Ho
Thanks Dave, makes perfect sense.
A lot of people aim to achieve nothing in life - and have amazing accuracy. |
HQ and HJ-WB doors are interchangeanble, but the glass and runners aren't. Edited by user Monday, 5 December 2005 7:59:10 PM(UTC)
Sorry to be a bit picky Byron, but the HJ - WB glass and runners as a set are interchangable with the HQ equivalents. You just can't mix and match the HQ glass or front runner with the later glass or front runner.
Cheers...Dave
