Hi all, Does anyone have any pictures or know of anyone who has twin turboed either a HK/T/G holden. My son and I are in the stage of trying to decide on intercooler sizes and mounting positions. To this point I haven't been able to find any info or foters. Plenty of commodores etc but nothing on what we are doing. Any info, contacts or foters would be most welcome. Merry xmas all. Regards, Glenn
Thanks: 1 times Was thanked: 636 time(s) in 598 post(s)
I know a dude that has had a turbo 186 HK GTS for years. But, 'back in them days' such conversions didn't use intercoolers. Have a look at the latest Street Machine front cover. If you can twin turbo and intercool an LC/J then a HK-HG should be a snack! |
i have a twin turbo 186 in the build at present. planning to put it into an HG whent he current 186 dies (which is a LONG way off). not after any kind of HUGE power, just a boost in daily performance and something a bit different.
are you doing an 8 o
Hi guys have a twin turbo 253 in a hz wagon which apart from sump differing and clearance around steering box is close to hg or such im working on twin water to air coolers but at the moment its not i-cooled seems fine just limits boost and ignition
Hi Guys, Thanks for the replies. We are using a 355 Holden running straight gas with twin garrett roller gt28 turboes. These are the same turboes used on the LS1 twin turbo kits. They have a small exhaust housing as we want it to boost early and also
Im building a turbo 186 in a hg at the moment. i dont know if im going to use one ot two turbos at the moment.
