G'day all, I was wondering if someone can help me out here? I have a spray gun that came in one of those starter kits from bunnings that I got when I bought my compressor a few years back, I've never used it and it has no documentation , I presume it is a low pressure gun, but I have no idea what pressure to use with it. I have only ever used high pressure guns so I have no idea aboput this gun.I realise its a cheapie and not to expect a good finish, but, I am saving for a good quality gun to paint my ute with, but in the meantime I was going to use the cheap gun to paint a few items where the finish isnt as crucial,like a pair of inner guards, battery tray and radiator support panel that are waiting to go on. Any help here would be appreciated.Thanks.Russ.
You know as much as I do. Any pictures of the gun or brand name/ model number? Try it out and see what happens? Can't help without any information. |
use no more than 40psi, even with a good gun around 40psi is plenty to paint a car.
Hi Russ,
How many adjustment knobs are on it ? And where are the knobs found. Apart from the one on the front...it doesnt count.
Cheers John
Why must good folks as youself buy your equipment from Bunnings if you want a quality spray job buy quality products and give Bunnings a miss,go talk to a specialist some one who sells automotive paints they will have all the equipment required as well as
I can recommend the Star 770 as a good budget gun that is easy for a novice to master.
Used to buy them in bulk at my old job, and the casuals could pick up spraying in a few hours with them.
Mick ________________________________________ |
Iwata 707 is another good one for around $140.00
The gun should have a max pressure on the bottiom of the can. I use about 20 to 30 with my low pressure one, no more. If it is a low pressure gun, the bottom of the can can go from concave to convex with too much pressure.
Experiment with a bit of scra
The old Star 770, what a classic gun. Copy of the Iwata 77. Yep I agree, for $100 for a Star or $140 for the Iwata, you will have in your hands a gun capable of being used in a correct manner, and designed to do so. I will only say that the cheap cheap gu |
