Hi i was looking at an australian hotrodding site and i saw a few posts on using Toyota hilux diffs behind 308s and other v8s. The claim is that they are as good as a 9inch and weigh no where as much as the 9inch. I also like the advantage of bieng able to to get air lock kits from places like ARB so that you can have a locked diff at the flick of a switch. Anyone out thier know of anyone using one of these diffs behind a decent motor ? I know of a guy who has one behind a 10sec mazda rotary that wheelstands. Anyone one else got any info?
Not the BLOODY Kingswood |
i dont no much about it but it would be interesting to find out zac
Nothing beats cubic inches !!!
Try the forums on this site http://www.ozrodders.com/ their is a bit of info about them |
I wouldnt believe that they are as tough as a Ford 9" I own a Toyota Tarago (Bubble shape 90s model) same diff as the Hilux, and I spat two teeth of the crown wheel early this year. I might add that the replacement cost is equal to a 9" though. Still got
I wouldn't believe that they are as tough as a Ford 9" I own a Toyota Tarago (Bubble shape 90's model) same diff as the Hilux, and I spat two teeth of the crown wheel early this year. I might add that the replacement cost is equal to a 9" though. Still g
One of the problems with V8 conversions in Hiluxes is that they break diffs and gearboxes. The boxes are basically Supra boxes. There is a dude that makes stronger diff centres that easily handle a 308 though. The indestructible thing in a Hilux is the tr |
i have heard of people putting hilux diffs into vt commodores.
To make 4x4s? Otherwise why would you do this?? |
Hi Guys.
A Hi-Lux diff is a tough little unit, but it's no 9". They do break in stock street cars, but then again so do early 9". When people talk about 9", they usually mean the 4-pinion LSD unit fitted standard behind 351 Aussie Fords, these have tou |
Hi Guys.
A Hi-Lux diff is a tough little unit, but its no 9". They do break in stock street cars, but then again so do early 9". When people talk about 9", they usually mean the 4-pinion LSD unit fitted standard behind 351 Aussie Fords, these have toug |
So a 4 pinion Borg Warner as fitted to later Commodores with 31 spline billet axles would be a good light choice with LSD and a good number of ratios available? Would it be stronger than the Hilux diff? |
I'll go along with Dr Terry. There are lots of different styles of 9"diffs some stronger by a fair amount than others. But even the weakest 9"would be stronger than a hilux diff.
The other thing to consider here though is what sort of car your planni
Ill go along with Dr Terry. There are lots of different styles of 9"diffs some stronger by a fair amount than others. But even the weakest 9"would be stronger than a hilux diff.
The other thing to consider here though is what sort of car your plannin
We have a Toyota Crown diff in our ratrod and have never had a problem then again we drive very sensibly never spinning the wheels, I would have to say its a great unit for our needs.
what about a diff from a troopy
Patrol is better and stronger. Tallest ratio is 3.9:1 out of most Mavericks and some TI Patrols.
I think the weakest thing in a Hillux is the Diff, Ive had mine rebuilt twice in 350k ks. The 1st time cost $ 700 and this second time $950 (with the Crown wheel being replaced). It seems ok now. Other than the Diff (for a 95mod) the thing hasnt Ev
I think the weakest thing in a Hillux is the Diff, Ive had mine rebuilt twice in 350k k's. The 1st time cost $ 700 and this second time $950 (with the Crown wheel being replaced). It seems ok now. Other than the Diff (for a 95mod) the thing has'nt
Which Hilux diffs are we talking about here??
the early ones that look like a holden banjo can't be too stong, or why would people convert to Lancruiser diffs when they run 308 in Hilux? Also, Hilux's are good wreckers, ALWAYS manage to sell the diffs |
the early ones that look like a holden banjo cant be too stong, or why would people convert to Lancruiser diffs when they run 308 in Hilux? Also, Hiluxs are good wreckers, ALWAYS manage to sell the diffs, |
