#1 Posted : Thursday, 19 January 2006 8:15:31 AM(UTC)
Hi guys.
Can someone give me some info on how to tune the XF twin barrel carby that comes standard on the alloy head 4.1 engine?
My car is running a bit rich and I want to lean it off a little.
Cheers, Pete
#2 Posted : Thursday, 19 January 2006 9:05:45 AM(UTC)
If it is running rich at idle you can adjust idle screw on carb which is located on lh side at base you will need a very short screwdriver to fit between tower and carb if it has never been touched it may have a cap in the hole,if it is running rich under
