hey all i no its been dun over and over but ther are sum things i want to no im puting a efi 304 into my gts monaro. not 1 thing i want to no is how do i get the speed sig back into the ecu? as im not runing the vn dash and what about the oil swich i got told to yous a t pice but wont i get a low psi as its stliting it into to swichs. and how do i go about linking up my try shifter to yous it on the t700????? and what tail shaft do you yous ? thats about it for now. and plz dont telll me to go to the rod shop or v6 conver. as im doing it myself. thanks
Thanks: 1 times Was thanked: 636 time(s) in 598 post(s)
Speed signal - you need to either buy or make a pulse adapter and a T-piece for the speedo cable. Both of these can be purchased from Castle Auto electrics.
Oil pressure - use a brass or stainless T-piece. You are measuring pressure, not flow so splitt |
