#1 Posted : Sunday, 29 January 2006 10:08:18 PM(UTC)
HELP.. I HAVE COME ACROSS A 351 ENGINE BLOCK ,THAT I AM TRYING TO FIND OUT WHAT IT IS OUT OF .ITS A D BLOCK DOAE-J WITH 0C19 NUMBERS ON THE BOTTOM AND 0C31-G STAMPED ON THE FRONT . I HAVE BEEN TOLD THAT 0C19 MEANS 0=1970 C=MARCH 19=19TH THE DAY THAT THE BLOCK WAS MADE AND 0C31 IS 31ST MARCH 1970 THE DAY THE ENGINE WAS PUT TOGETHER. THE BIT I DONT KNOW ABOUT IS THE ENGINE NUMBER .ITS ON THE LEFT SIDE ,LOOKING AT THE BLOCK FROM THE FRONT.THE NUMBER IS S1375C OR HS1375C. I HAVE BEEN TOLD THAT THIS IS A BATHURST BLOCK BECAUSE ITS A S BLOCK ,BUT THERE SEEMS TO BE A BIT OF A OUT LINE OF A H IN FRONT OF THE S BUT IT IS VERY HARD TO MAKE OUT ANY IFO WOULD BE HELPFULL
Munromad2004 Offline
#2 Posted : Sunday, 29 January 2006 11:24:30 PM(UTC)
Munromad2004
The engine number is on the right hand side looking from the front of the car.
It should be on a little flat near the front of the passenger side cylinder head.
If it's an aussie built car it will start with JG
A Bathurst block is a load of ****.
#3 Posted: : Monday, 30 January 2006 3:25:08 AM(UTC)
THANKS FOR THE REPLY MUNROMAD2004 ,THE ENGINE NUMBER IS ON LEFT HAND SIDE OF BLOCK ,ALL 351C ENGINE NUMBERS BEFORE 1971 WERE ON THE LEFT HAND SIDE . FROM 1971 ON IT CHANGED TO RIGHT HAND SIDE ABOVE FUEL PUMP, SO I HAVE TOLD. IF THIS BLOCK IS A AUSSI BLOC
XB351 Offline
#4 Posted : Monday, 30 January 2006 3:44:57 AM(UTC)
XB351
It could be a US block or a block that had no number so the road authorities gave it one. Hence the weird no?
#5 Posted : Monday, 30 January 2006 4:55:04 AM(UTC)
THANKS XB351 , YOU COULD BE RIGHT . JUST WANTED TO KNOW IF ANY BODY HAD CAME ACROSS THIS STRANGE ENGINE NO BEFORE ,OR HAD CAME ACROSS A GT BLOCK LIKE THIS .
Paul351xb Offline
#6 Posted : Monday, 30 January 2006 5:43:51 AM(UTC)
Paul351xb
Might be a Canandian Block.
Jim140862 Offline
#7 Posted : Wednesday, 1 February 2006 1:35:26 AM(UTC)
Jim140862
Hi Monza. I also have a block with an unusual number. Rather than interrupt your theme here, I just made a new posting (above)if you want to have a look at the details on mine.
#8 Posted : Wednesday, 10 May 2006 4:08:37 AM(UTC)
Engine is out of XW V8 ,the engines in thes cars didn't have JG or JH prefixes on them,also bathurst engines had QC stamped on them.
#9 Posted : Wednesday, 10 May 2006 5:01:03 AM(UTC)
i had a D block which had the engine number that stared with HS not realy sure what it came out of?
#10 Posted : Saturday, 13 May 2006 6:11:20 AM(UTC)
im so glad i found this site, i need help i have a mystery ford engine a 302 or 351 i can't tell the difference i have engine no.s if u know what it is would be a great help. JG37NM
7463K
This page was generated in 0.264 seconds.
