hi there, i have a bosch electronic dissy that i want to put in my hg workute, it is a scorcher electronic that is modified to fit a chev engine,there are 2 wires coming from the dissy that are coloured light green and pink, i take it the green goes to earth but where does the other one go?, any help greatly appreciated , cheers
If it's like the GMH HEI system then green goes on the coil negative terminal (the points side) while pink goes on the positive (ign sw) side of the coil which is in turn connected to ignition.
Mick _________________________________________ |
