i just bought a 1984 vk vacationer 4 speed manual with a 202 what can i do to make it go faster and run better
How fast do you want to go? :D Pipes, Cams, Cold air intake, Bump Compression. Some tweek the TPS for better fuel delivery. Thou I think this is pretty shaky, And the results are hit and miss? Cams are pretty mild for the EFI Models due to there Fuel Edited by user Sunday, 5 February 2006 5:28:01 AM(UTC)
| Reason: Not specified |
Never stop being inspired, You may never realize your full potential. |
First thing to do would be to fit a set of extractors and a good exhaust system,then a good dyno tune that should get you some power,then go from there.
if it ain't broke we can improve it.
Cheers Steve
Thanks: 1 times Was thanked: 636 time(s) in 598 post(s)
Honestly, and not trying to be smart, but in my opinion the cheapest and easiest way to make it go better is to buy an original V8 with a crook body and transfer it all over. These cars are in the papers all the time for $500 - $1500. Bang for buck you wo |
ifu want to go fast buy a wrecked vp v6 and bolt the complete drivetrain in. u will need an vl pwr str coupling from a wreckers and wiring harness from castle auto electrics to do job.vl 3.45 ratio diff and u will b flying
I had a Vk And i just put extractors on it and a bigger carby, also i had a 4:1 diff ratio, but he is right just buy a v8 if your going to work on a vk mate
You can take the head out to 40thou that will give you about 10:1, the cam is not mild it is about the same as the XU1, except retarded at low speed to allow lower emissions, extractors are standard, how much do you want to spend?
would it be cheaper to buy a wrecked v8 vk and do it up or put a 8 the one i have i dont have much money and have allready bought this one for 2500 seams a waist of money
hey fellas, Im looking at buy this... along with other cars, voice ur oppinions, Im just going for my P's soon so I dont really want a super fast V8 or anything.
COMMODORE VK 1985, white, 202 black motor, 5 spd manual, Pacemaker headers, 2.5" exhaust,
