#1 Posted : Monday, 13 February 2006 6:36:04 AM(UTC)
ive been looking at geting an electroplating kit from eplate.com.au for a while now, does anyone know much about these kits and if they are any good?
#2 Posted : Monday, 13 February 2006 11:54:16 PM(UTC)
Yes I do, Had mine for aprox 18 mths and got it sorted...it is an art so practice makes perfect. I got the 25L NiCo kit, 25L soak cleaner (A MUST HAVE!!) and recently a 25L copper kit.
It's not easy prepping the surface first, the more time you spend t
#3 Posted : Tuesday, 14 February 2006 6:18:33 AM(UTC)
thanks for that, i will be getten mine in a few weeks
#4 Posted : Tuesday, 14 February 2006 7:42:17 AM(UTC)
What kits did you end up getting, did you get the soak cleaner?
#5 Posted : Wednesday, 15 February 2006 6:46:46 AM(UTC)
i havnt ordered any yet, just got to put some money together first.
GMH1975 Offline
#6 Posted : Saturday, 18 February 2006 5:52:38 PM(UTC)
GMH1975
Very interesting product.
Ive been told that Chrome plateing weakens steel and you have to heat treatit it bring it back to its original strength.
Is this true and would this stuff cause the same problem?
Not the BLOODY Kingswood
#7 Posted : Saturday, 18 February 2006 6:46:11 PM(UTC)
im not 100% sure myself, that is somthing im going to have to look into.
#8 Posted : Sunday, 19 February 2006 1:37:22 AM(UTC)
Apparently it is true, I enquired about hard chroming a crankshaft and was told they would not do it because of that problem but I am not sure this stuff is true chrome so it may not be affected, ask the dealer.
#9 Posted: : Sunday, 19 February 2006 1:40:49 AM(UTC)
Also about copper plating, the problem with chrome is it is porous so moisture penetrates it and rusts the metal underneath, so you need to copper plate it first to seal it, in the old days they used to copper plate then nickel plate sometimes they would
GMH1975 Offline
#10 Posted : Sunday, 19 February 2006 2:13:01 AM(UTC)
GMH1975
The price is a bit high unless you are going to be doing alot of chroming.
At roughly $1000 for the cleaning soulution copper kit and the nickel kit .
I had both the bumpers on my HX done for $300 the pair by pahran platers 3 odd years ago and a few o
#11 Posted : Sunday, 19 February 2006 4:15:20 AM(UTC)
Johnperth is correct in regards to chrome rusting through, the breakdown of the Nico is Nickel, cobolt, alloy. The problem with straight nickel is that is dulls off quickley, with zinc plating the zinc is a sacrifical coating deaigned to corrode first bef
