#1 Posted : Wednesday, 15 February 2006 7:03:31 AM(UTC)
I Got A 1984 VK Berlina with a carbie 202 and a 3 speed auto Today, And I want to know what it takes to change it to Unleaded coz putting in lead replacement is going to get old real quick.
peter_flane Offline
#2 Posted : Wednesday, 15 February 2006 7:57:05 AM(UTC)
peter_flane
Just put unleaded in it and you might be surprised and get ten years out of it before you get signs of Valve Seat Recession.
Once you start getting the first signs of VSR. Your mechanic will tell you, or the motor will with a bit of choof choofing. The
#3 Posted : Wednesday, 15 February 2006 11:58:49 AM(UTC)
Ummm, I think Peter meant PULP...VK's don't usually run very well on regular ULP. Normally, you'd back off the timing or drop the compression to run normal ULP. However you can't back off your timing in a carby VK unless you fit a Blue motor dizzy and get
peter_flane Offline
#4 Posted : Friday, 17 February 2006 8:57:38 AM(UTC)
peter_flane
Well PULP is a form of unleaded petrol, that's what I meant. We don't have LRP anymore.
It is not always necessary to run out and get the head 'converted' just to run PULP.
My wifes VW Beetle will run just as long on PULP, ULP, LRP, Super, Standard,
This page was generated in 0.154 seconds.
