Having sold my project van I now have the power steering setup I was going to fit. It is a 6 cylinder one. What would it be worth?
Thanks: 1 times Was thanked: 636 time(s) in 598 post(s)
$250 - $500, condition dependant. |
I see there is one on Ebay now will see what happens with that. i wouldn't part with mine under $400-$450 when you see HQ ones go for 3 or 400, and there are plenty of them around. I would rather sit it under the workbench for a couple of years, like mone
I see there is one on Ebay now (item 8044657729) will see what happens with that. I wouldn't part with mine under $400-$450 when you see HQ ones go for 3 or 400, and there are plenty of them around. I would rather sit it under the workbench for a couple o
I sold a COMPLETE system a few months ago for $350 and have seen a couple go for $450.kicked myself for not going higher in price, but....
If It Aint Broke- Dont Fix It, Modify It! |
be an innovator, not a imitator |
John, misread your post. I read it as HQ-WB for some reason. For a HK-HG Chev setup expect to get $600+. For a 6cyl/253/308 setup a few hundred less. |
This one is a 6, but what is the difference?
the chev has a bend in the link
The chassis bracket (on the passenger's side) plus the pump/lines etc. The 253/308 is the same (except for the engine stuff) as the 6cyl setup. |
