hey ive got a vg 1990 5 speed manual ute and looking at putting a new throttle bodie on it i have a few mods already done to car like extractors,2.5 inch system with side pipes , memcal mod chip and cold air intake is it worth my time getting a 70mm throttle bodie on it or should look at a few more differnt mods first like rocker rollers , new cams , injectors and so on ?????? thanks regards mark
What motor? V6 or V8?
A lot of people aim to achieve nothing in life - and have amazing accuracy. |
Just grab yourself the V8 throttle body and whack it on. It is a bolt-on fit, and all the sensors & hoses are in the same locations.
The motor won't flow enough air to warrant more than that.
If it's an update V6 (some 1990 ones were) then you can |
When you say 2 1/2" with side pipes are you just talking about a single system or have you gone a twin exhaust? What sort of HP would you like to get upto?
life's to short not to be....
yeah its a sinlge 2.5 exhaust with the side pipes off the cat ill grab the 70 mm throttle bodie then and look into some rockers you reakon mend any rockers ???
the throttle body is on ebay but the guy said i can have it for $260 this is link http://cgi.ebay.com.au/B...2624QQrdZ1QQcmdZViewItem
