Fastlane
Holden Forums
Holden General Discussion
Holden engine number prefix reference
I've heard of HQ racers liking the "3 rib block". Never knew why though.
If it's only got 4 numbers it's an early VB block. I've seen a few early red Commodore blocks with 202 on them. Not sure when the 3.3 became standard, possibly when Qx numbers ran |
Ive heard of HQ racers liking the "3 rib block". Never knew why though.
If its only got 4 numbers its an early VB block. Ive seen a few early red Commodore blocks with 202 on them. Not sure when the 3.3 became standard, possibly when Qx numbers ran out |
You are a member of these groups:: Guests
can u put a blue 308 in a 1985 holden commy
yes well they came out like that the 304 didn't start till late 86 I think and through the VL I might be wromg?
it's beer o'clock |
On The Other Hand There's Finger's |
yes well they came out like that the 304 didnt start till late 86 I think and through the VL I might be wromg?
its beer oclock |
Hey guy's new to this fourm, also sorry its a big post. Any way i was shown this thread by commodorenut as my brother's VQ statesman 5ltr 1992 series 2 also has the block prefix of SVU. Ive read what has been said about it and my Brother and me are happy Edited by user Wednesday, 10 October 2007 5:17:10 AM(UTC)
| Reason: Not specified
Hey guys new to this fourm, also sorry its a big post. Any way i was shown this thread by commodorenut as my brothers VQ statesman 5ltr 1992 series 2 also has the block prefix of SVU. Ive read what has been said about it and my Brother and me are happy wi Edited by user Wednesday, 10 October 2007 5:17:10 AM(UTC)
How do you know its 200 flywheel kW?
How do you know it's 200 flywheel kW?
quote: Originally posted by Dr Terry
Hi Guys.
VU is the normal 5.0-litre EFI V8 & SU is the Genuine parts replacement block |
______________________________________________Edited by user Wednesday, 10 October 2007 9:28:54 AM(UTC)
_______________________________________________Edited by user Wednesday, 10 October 2007 9:28:54 AM(UTC)
I understand it was dynoed, but to know it has 200kW at the flywheel means the engine was pulled out and put on an engine dyno. Otherwise its an estimate based upon rear wheel kW that is not very accurate. Why I asked is that these engines were rated at 1 |
I understand it was dynoed, but to know it has 200kW at the flywheel means the engine was pulled out and put on an engine dyno. Otherwise it's an estimate based upon rear wheel kW that is not very accurate. Why I asked is that these engines were rated at |
Ok, so it could be a 185kw from factory, I think that sounds right as the computer chip does look diffrent compared to other car i think my bro said, its been a while since i talked to him about it. Tho it does pull away from other 5ltr's very easly. e Edited by user Wednesday, 10 October 2007 5:33:52 PM(UTC)
Ok, so it could be a 185kw from factory, I think that sounds right as the computer chip does look diffrent compared to other car i think my bro said, its been a while since i talked to him about it. Tho it does pull away from other 5ltrs very easly. ed Edited by user Wednesday, 10 October 2007 5:33:52 PM(UTC)
Both. Only difference is SVU is in a Statesman. If it's a VQ I think the HSV/HBD were still 180kW, and the 185kW was VR or VS pre VM engines from memory. (Except for the VM prefixed VSIII/VT engine - also not sure if these had SVM for the 195kW HBD VSIII |
Both. Only difference is SVU is in a Statesman. If its a VQ I think the HSV/HBD were still 180kW, and the 185kW was VR or VS pre VM engines from memory. (Except for the VM prefixed VSIII/VT engine - also not sure if these had SVM for the 195kW HBD VSIII S |
quote: Originally posted by commodorenut
quo
I find it hard to believe, in the 130cid, in a HT-G Export motor, should it be a 138? i have seen them 138 in LC toranas with a 2250 badge guards, but never seen a 130 in a torana, and never seen a 2200 badge torana in aus. i would think the 138 and 161 1
Fastlane
Holden Forums
