I am looking for a shifter for a 6 cylinder 5 speed box. What would be a fair price and does anyone have one? Or are these rare?
Check out 5 speed sigmas, bluebirds, stanzas & other Aussie assembled cars of around 2L rear drive, from that period (1981-85), because, they all ran variants of the same 5 speed box in certain models in their line-up.
Mick ________________ |
The 5 speed box that came out in the VH was only available behind the 2.85lt 6 cyl and 1.9 4 cyl engines. Apparently is was piss weak and could not handle the torque of the 3.3 lt 6.
Not sure what engine you plan to run with it, but i would be looki
VK 3.3L carby 5 speed is the same box as the 2.85L VH unit apart from some selective shot-peening of the internals to make 2nd gear a bit stronger.
They were rated at 200Nm, and the stock VK carby 6 was capable of 231Nm.
Mick ___________ |
Thanks guys. I am actually looking for one for a box I sold, I told the guy it did not have the shifter and pointed it out again to him when he picked it up, now he has come back whinging he can't locate a shifter. I thought i would at least try to help h
XE 3.3 & early XF 3.3 Falcons had this five speeder as an option too. be warned though Later XF's had a T5. |
