Fastlane
Holden Forums
Holden General Discussion
Boat trailer wheels - what are they??
I have a boat trailer which when I bought it was told had new axles, wheels and tyres. Only problem is there is no spare.
The rims are 4 stud 14" with 5 1/2" x 14" rims. I thought they might be Datsun rims - however upon inspection the rims have and GM stamp followed by WB - I know they are not WB rims. Could they be earlier model HOlden rims. How do I tell. I need a spare or two nice alloy mags and keep the rims for spares.
cheers,
Scott
Joined: 2/03/2005(UTC) Posts: 491 ![Australia Australia]() Thanks: 3 times Was thanked: 8 time(s) in 8 post(s)
Scott, sounds like you have 4 cylinder commy wheels. Al.
4 cyl commodore wheels were still 5 stud - same as torana pattern.
4 stud could possibly be Gemini, although I think they only went up to 13" rims until the FWD ones.
Most likely your best bet is to change the hubs to the same as your usual towcar, and buy a set of wheels to match, that way you can use the same spare. The trailer people can supply hubs drilled to any pattern you want. You are changing the wheels anyw
4 stud 14 inch would be camira je model...should look like chaser rims with holes all round...same stud pattern as gemini and bmw.. |
Hi Scott, No idea what your current rims are, but if you measure the PCD (across diagonally opposite studs on a 4 stud hub) and take that measurement to a tyre/wheel place, they will be able to tell you what has the same stud pattern. Then you just hav Edited by user Saturday, 1 April 2006 8:42:28 AM(UTC)
| Reason: Not specified
I had the same problem with mine but I had 10" rims, they turned out to be rims from a mini minor. I found a spare at a swap for $1.00
Thanks for your help guys. I will follow up with the Camira/Gemini wheels. What is thew PCD for Camira/Gemini wheels ( iguess it is the distance diagonally acrosos from each stud).
Does any one a either single steel spare for a Gemini/Vamira or a pair
we use a je camira ute for the yard hack..even though i dont wreck them...if you get stuck i should have a steel wheel floating in the yard somewhere..you shoudnt have a problem picking one up in sydney at the wreckers for 20 or less... |
If you find that they are Camira wheels & you can't locate any AE92 Corolla wheels have the same PCD so they should work. |
Camira & Gemini have the same stud pattern, but a different offset.
A lot of people aim to achieve nothing in life - and have amazing accuracy. |
Fastlane
Holden Forums
