#1 Posted : Sunday, 16 April 2006 4:12:25 AM(UTC)
Hi Everyone I am in the process of cleaning under the ute at the moment after 27 years there is some real **** built up under there. Anyway I want to remove the fuel tank so I can redo all the hoses and clean it all up is it big job to do it, and can you do it on your own thanks.
#2 Posted : Sunday, 16 April 2006 6:45:27 AM(UTC)
Hi Dan,
It isn't a huge job and you can do it yourself. However, it is an awkward job.
Getthe ute as high as possible into the air and support with jackstands.
Make sure the tank is as empty as possible so it is as light as possible. Disconnect a
