RJR Offline
#1 Posted : Saturday, 24 June 2006 11:03:48 PM(UTC)
RJR
Gday Aussies,
can you guys tell me, I have a red 202 with a 5speed celica box to drop in my FJ and was curious to know if the gear stick is going to be well clear of the bench seat
#2 Posted: : Sunday, 25 June 2006 12:08:26 AM(UTC)
my brother got a conversion for a 5speed celica box for his 186 from rod shop in castlemaine anyways he put it in his EH but had bucket seats
RJR Offline
#3 Posted : Sunday, 25 June 2006 1:03:28 AM(UTC)
RJR
thanks acey but need to know for the FJ conversion
#4 Posted : Sunday, 25 June 2006 6:29:29 AM(UTC)
Which version of the Celica box do you have? They can have the shifter right at the back of the box (basically above the collar around the yoke) or where the plate for the above bolts to the box or about 2" forward of that.
From memory, the forward-mos
Edited by user Sunday, 25 June 2006 6:31:31 AM(UTC)  | Reason: Not specified
#5 Posted : Thursday, 29 June 2006 6:36:58 PM(UTC)
Hi,I have a 5 speed box fitted to a 202 in an FJ.The hole you will need is 100x100mm and is 600mm from the bottom of the crease area on the firewall to the centre of hole and 300mm from the centre of the crossmember under the front seat to the centre of h
This page was generated in 0.201 seconds.
