Just a short question. I have only just recently moved to Adelaide from Brisbane and the driving I do has gone from highway to city. If I have the 2.75 ratio in the ute now what would be the better ratio to replace it. Keep in mind i have been down here for over a month and have not got up to 80kms yet. Is 3.55 as far as they go in a 10 bolt or do they go further? How easy is it to get ahold of these ratio's? Has anyone got one for sale?
Cheers Chris
If a man say's something in the woods and there is no women around, is he still wrong? |
Hi Chris.
What car, what engine (any mods) & what gearbox.
All of these have a huge bearing on the answer.
Dr Terry. |
I'm going to make an assumption that its HQ in your avatar...but you would still need to provide the detail the Dr. asked for.
I beleive they go to 4.44:1 in the one tonners?
Sorry didn't think. It's a HX Styleside ute, 308 T400. As far as I know the motor is standard, just reconditioned a short while ago I was told.
If a man say's somethin |
Hi Chris.
A 2.78 or 3.08 is good for a 308 TH400 combination. HX, HZ & WB Statesmans use a 2.60 diff no problems. A lower diff ratio is only required if your motor doesn't have enough low down torque to get you you car going at low speeds or if you hav |
Hi Terry, I seem to recall we discussed this late last year? Styleside = normal ute (as opposed to a tonner). Stepside = What the yanks call a pickup. Trayback = Tonner style. BTW, I'd reckon a 3.36 or taller (lower numbered) diff would be Edited by user Friday, 30 June 2006 10:07:49 PM(UTC)
| Reason: Not specified
Hi Dave.
I remember part of the conversation, but I thought a stepside was where they had the narrow ute body & protruding guards like a box trailer but more rounded.
These are Yank terms that really don't apply here, our utes are officially called |
I thought the body with the guards sticking out etc was a styleside, the ordinary ute bodies were well bodies, and the tonner type was a traytop. personally i don't like the term pickup, Australia invented the ute and called it a utility, so why not go w
That was the other term for a "normal" Aussie ute that I couldn't think off earlier...a well-body. Thanks John.
You are spot-on in your description of a stepside Terry.
The term Styleside was actually used by GMH and Ford in the 30's to describe the
3.08 would be the best diff ratio. Good cruise rpm, will pick up a little performance, and maybe some fuel economy. If you go any lower(higher numericly)with a std stall convertor, then you just loose torque multiplication in you convertor. Won't hurt an
Years ago I replaced the 3.08 in my Torana (202 red with Opel box)with a 2.78 LSD. I left it there for only a month or two before swapping back to 3.08. Fuel consumption increased 10%, top speed reduced 10%, pick-up reduced 10%, and I had to run in lower
Hi David.
That's what I meant when I said,
"A lower diff ratio is only required if your motor doesn't have enough low down torque to get you you car going at low speeds".
A stock 202 manual will not have enough torque to 'push' the 2.78 diff, |
Hi Dr Terry,
A few weeks ago a bloke was flogging a 2.78 LSD on ebay. His claim was that it improved fuel economy (by reducing revs) behind his heavily worked 186 with 4-speed in Torana. I guess he sold it - I didn't follow it. I wonder what the purcha
I would suggest even a 202 would have trouble with a 308 ratio. A 336 manual or 355 auto runs ok with them.
