This goes against everything I know about HT/G versus HK sedans... How was it done? eBay item# 290002549330 http://cgi.ebay.com.au/H...ar_W0QQitemZ290002549330
Hi kim.
You'll have to be more specific, do you mean the HK rear doors on an HT/HG body.
HK doors will bolt on, all you have to do then is to grind a bit off the gutter & bog up the gap that is left in the C-pillar. I've seen cars driving around wh |
Thanks Dr Terry, yes that's what I meant. I thought the groove on the c-pillar would have ended lower on the T/G, thus not aligning with the higher groove on the K?
Hi kim.
Yes, that's what I meant, they just fill the groove (in the C-pillar) with bog for the lower 2 or 3 inches. Seen it done many times.
Dr Terry |
sorry, yep, I get what you mean now. I think I confused myself with the opposite conversion. Never have seen it myself though.
