#1 Posted : Tuesday, 11 July 2006 9:19:57 AM(UTC)
Hi can someone tell me if there is a 2 pack spray putty or a high build primer or the correct name to ask for please and how thick u can apply thanks heaps fbbad
#2 Posted : Tuesday, 11 July 2006 10:59:10 AM(UTC)
i always thought that spray putty was just that. no 2 parts about it. from memory spray putty is painted as an 80/20 mix. 80% material and 20% thinners and the best way to spray it is with a gravity feed gun.
#3 Posted : Wednesday, 12 July 2006 4:31:58 AM(UTC)
2pak primer filler you also need to mix 4:1 with hardner/activator 4 being primer
peter_flane Offline
#4 Posted : Wednesday, 12 July 2006 6:04:15 AM(UTC)
peter_flane
You MUST go to an automotive paint supplier and they will help you. There are hundreds of different versions, combinations, styles, ideas, products etc. All ideas are correct in some way, but you need to identify what suits your needs. Yeah?
