Did geminis have webers carbs standard? which model Webers and which model geminis? thanks
Hi johnperth
AFAIK all Holden Geminis with petrol motors use Nippon Kikaki (Nikki) 2 barrel carbies, as do Rodeos & Jackaroos with similar motors.
The aftermarket 'CDT' Geminis had Webers on some models from memory. The problem was of course that We |
Thanks mate. Trying to fid cars that had webers standard.
Hi johnperth.
It depends what type of Weber you're after, but generally speaking they aren't used on Jap cars, but are used on many European & Pommy cars.
If you're meaning the 2 barrel down-draught variety, these were common on 2 litre Escorts & C |
Thanks dr. Terry apparently the one I need is the fiat 800 type, whatever that is.
