Ok so the overheating is on hold now as when i was playing around today a new leak showed itself just under the thermostat housing between the manifold and the block, so its time for a new manifold.
Have checked out machining costs and have opted for new. Should i stick with the standard or go for something in the way of an edelbrok performer? i have been looking at different options and have noticed that on my standard one there are two hoses that run into the manifold just in front of the egr valve, one runs to the carby not sure about the other off hand. On some of the performance manifolds i have noticed this is not present, do they make edelbrocks and the like with these holes?
Thanks for any opinions and your help.
For standard to mild performance go for the Kilkenny KC308 inlet manifold. It is an aftermarket manifold based on the HDT designed performance manifold
Thanks: 1 times Was thanked: 603 time(s) in 570 post(s)
The Edelbrock is not made to suit the EGR heads.
James
You only have to be in front at the end of the race. |
I have what was known as the "Brock manifold" for sale if you are interested. It is a dual plane manifold, and in very good condition. Genuine GMH manifold.
In thrust we trust |
Thanks guys, will go with the kilkenny KC308, where could i pick one of these up from? im at gosford on the central coast, NSW, and how much are they going for?
kc 308m is the part number used...a bit over 400 on the net...generally cheaper offline by more than 15%...do a search on the rare spares website as they are listed there and then ring american auto parts and see what there over the counter price is..... |
