#1 Posted : Wednesday, 2 August 2006 8:38:08 AM(UTC)
I own a 67 Falcon Coupe and 65 Mustang Coupe. Both need 3 point seatbelts to make driving them a bit more reassuring. The problem is no B pillar in the case of the Mustang, and a B pillar which is way to the rear in the case of the Falcon coupe. My solution was to have a retractor at the base on the RHS and above in the roof, Both would then pull down and click into the same buckle near the centre of the car. Has anyone solved this conundrum?
Paul351xb Offline
#2 Posted : Wednesday, 2 August 2006 9:14:29 AM(UTC)
Paul351xb
Most of the harnesses I've seen done here were mounted into the rear parcel shelf area. Means nobody can sit in the rear seats though.
philaa Offline
#3 Posted : Friday, 25 August 2006 5:49:54 AM(UTC)
philaa
Hi Keith,
I recently got a pic sent to me from the fodforums website for a link with a pic of a coupe that was recently at the all ford day in sydney. it looks like it has the top anchor point of the belt fastened about 3/4 up the B pillar.... if you wa
regards
phila
