#1 Posted : Thursday, 3 August 2006 3:25:11 AM(UTC)
You have been a member since:: 2/09/2015(UTC)
any way to get speedo on h.q. to read something like after
fitting toyota g/box.
(2) have been told if i fit later type rocker cover with
second pipe into air filter cover and sealed cap instead of
breather this will create vacum in crank case and help prevent oil leaks ? rod
#2 Posted : Thursday, 3 August 2006 5:49:19 AM(UTC)
You need to figure out how much your speedo is wrong in percentage terms (reads 90 kmh at 100 kmh so is 10% slow, etc) and then get a ratio reduction box made up that goes between the box and your speedo cable. Automotive Instrument companies make them.
