#1 Posted : Saturday, 12 August 2006 8:00:26 PM(UTC)
Hi guys,how much should a power steering pump cost,and are they hard to fit
regards uppy
uppy
#2 Posted : Thursday, 17 August 2006 9:08:59 AM(UTC)
If you can get someone to remove the front pulley for you, they are easy to repair as it's usually the o rings that need to be replaced because of oil leaking, the o rings kit will cost you about $15.00 POWER STEERING PUMP SEAL KIT P/No 333001k from Beari
#3 Posted : Thursday, 24 August 2006 7:11:59 AM(UTC)
thanks ,for thehadvice I will be following it up
regards uppy
