#1 Posted : Wednesday, 30 August 2006 5:38:47 AM(UTC)
i drop a 250xflow in my te cortina from a falcon but need a proper xmember to pass roadworthy what do i do?
#2 Posted : Thursday, 31 August 2006 3:41:51 AM(UTC)
Is it manual or Auto?
As a 250xflow were standard in the TE -The crossmembers are the same Are you using the standard box? If so the te crossmember will fit
sportycorty Offline
#3 Posted : Thursday, 31 August 2006 5:06:28 AM(UTC)
sportycorty
You have been a member since:: 30/08/2006(UTC)
falcon manual box. i shorten the layshaft 100mm and made an adaption plate so the shifter came up in the floor right. found a short tailshaft but cant find a xmember or any info? was a 4cyl cortina.
#4 Posted : Thursday, 31 August 2006 5:41:17 PM(UTC)
ok maybe you should go to CORTINA CENTRAL this has been done before.the falcon and cortina g/boxes are the same but the cortina extention housing is different so the shifter location is in the right spot as you know,they are interchangeable between both b
sportycorty Offline
#5 Posted : Friday, 1 September 2006 2:12:38 AM(UTC)
sportycorty
that makes sense now, no wonder i cant find an xmember, mounts weld to body different. my convertion from 4cyl to 6cyl is so close to finish just this little problem. didnt find much a cortina central but thanks
#6 Posted : Friday, 15 September 2006 7:52:12 AM(UTC)
just get a xd xmember and cut till fits we did it and never had any probs with it
