#1 Posted : Sunday, 8 October 2006 5:17:46 PM(UTC)
Hi im trying to adapt a bigger diameter flywheel to a red 202 used in a truck with the hope of running a large clutch to cope with the load at the moment i run a blue flywheel and 9.5 clutch which is not big enough i was wondering if any of the v8 holden flywheels had the same crank bolt pattern as the red 202 or may be easily adaptable i would appreciate any othet advice on how to end up with about a 10.5 or 11 inch clutch behind a red 202
#2 Posted : Monday, 9 October 2006 9:04:11 PM(UTC)
I don't think it's easy. I don't know of any 'standard' flywheel that will fit a red 6 that will take a bigger clutch. You will run into clearance issues with the bellhousing, plus getting a starter motor to fit will be difficult. I remember speaking to R
