#1 Posted : Tuesday, 7 November 2006 12:32:15 PM(UTC)
Roughly what mods would need to be done to put a 302 windsor with an auto behind it into a te cortina? I know about engine mounts/ gearbox mounts and chassis strengthening but what is the best way to upgrade brakes and to fit the radiator? Also will a bronco sump fit the car without modification? The car is currently a 4cyl four speed. cheers in advance
#2 Posted : Tuesday, 7 November 2006 9:14:05 PM(UTC)
Please read my replies to this topic:
http://www.fastlane.com..../topic.asp?TOPIC_ID=9013
Although I am writing about a Capri I think that the conversion specialists & sump information are also relevant to a Cortina.
There are two V8 mou
XB351 Offline
#3 Posted : Tuesday, 7 November 2006 9:30:52 PM(UTC)
XB351
You need engine mounts, starter to suit, custom shorty extractors for the TE/F. Most likely the same for the TC/D but I think the TC/D may have more room in the bay.
#4 Posted : Friday, 10 November 2006 11:27:21 AM(UTC)
What I was wondering mainly too if there were any body mods needed for to run the v8 auto and what diff would be the easiest to put in? cheers in advance
#5 Posted : Friday, 10 November 2006 7:54:23 PM(UTC)
Yes the TE/TF is a narrower engine bay than the TC/TD because it's chassis rails are wider & the engine mounts bolt to the Chssis on the TE/TF wheras they bolt onto the front cross member of the TC/TD.
If you are only using the 302 & you aren't going
#6 Posted : Wednesday, 28 November 2007 10:51:34 PM(UTC)
I'd also check the state regulations on changing the engine, in new south wales it needs to be engineered to increase the factory engine size by more then 10% (That includes putting the 250 crossflow into a 4 cylinder Corty which requires body strengtheni
#7 Posted : Saturday, 1 December 2007 1:07:00 AM(UTC)
About 20 years ago I had a TC cortina with a 351 cleveland & c4 auto fitted.It ran the standard diff(non LSD,but really needed it)and tyres were 225 wide so breaking diffs was not an issue,traction certainly was however.
The only body mods I can recall
