keithholden Offline
#1 Posted : Monday, 18 December 2006 4:27:14 PM(UTC)
keithholden
Hi I dont have any linkage and cant find one to go from my factory hq shifter to my recently installed TH400 Trans
Any ideas what I can use for this job??
Im in Christchurch and no wreakers hav these parts now.
cheers Keith
#2 Posted : Tuesday, 19 December 2006 3:23:49 AM(UTC)
you dont say if you have coloum auto or t-bar, what u need is the linkages from a statesman that ran a T400 or an after market shifter to suit, My HX runs a t400 and has a Hurst Promatic 2 shifter. Keep an eye on ebay also.
Fred Offline
#3 Posted : Tuesday, 19 December 2006 10:40:46 AM(UTC)
Fred
A supplier currently has these on ebay selling them as a new product $305.00 freight free.
Sandman Offline
#4 Posted : Friday, 22 December 2006 9:03:23 AM(UTC)
Sandman
After running factory shifters I changed to a B&M Megashifter. Best thing I ever did.
The HQ crossmembers aren't strong enough for a TH400 and when you hit bumps in the road, the crossmember will flex. Unless you have a near new shifter with no slop at a
keithholden Offline
#5 Posted : Monday, 25 December 2006 1:49:33 AM(UTC)
keithholden
Nice info about the flexing I wouldnt hav thought of that happening. My mate has welded braces into his one.
I have a factory floor change shifer maybe out of a prem? And a factory console.Linkage i need is just from shifter under car to trans.Not much
#6 Posted : Thursday, 31 May 2007 8:45:22 PM(UTC)
Hi there, I have a T400 in my tonner with a column shift that I bought from the wreckers from a Statesman. Cost $120 complete.
If you need a floor shift you can buy these from the wreckers, from Statesmans
regards Dave
#7 Posted : Thursday, 31 May 2007 8:53:27 PM(UTC)
Was thanked: 604 time(s) in 571 post(s)
Try a standard trimatic shifter rod of any HQ-WB with a floor shift trimatic. The connection to the shifter is the same, just on the other side. The connection to the transmission is through a "trunnion" with a setting screw, which also holds the trunnion
