Gidday all. Can anyone tell me what this red 202 engine is out of? Engine no begins with "VL". It isnt a 3300 as it has 202 cast in the block. Cheers and thanks for your help.........Brian Edited by user Wednesday, 3 January 2007 7:33:09 AM(UTC)
| Reason: Not specified
Red 202s with a VL prefix are VB commodore only.
A lot of people aim to achieve nothing in life - and have amazing accuracy. |
Interesting that it is not a 3300 but a 202. The 202 is a 3300 it just has 202 cast on the side until partway through HZ when it is changed to 3300. I always thought this happened before the Commodore release but must have happened after.
Warren
And to add to that, blue 202s had "3.3" cast in the side.
The reds I think were either cast 202 or 3.3, but the change happened during the HZ as I have seen a ZL 3.3 block.
Dr Terry might be able to assertain a more accurate changover as most of my research was on Monaros and they were All V8 by this time, so
Thanks guys. Does this mean i have to run pollution gear if i put it in my LC Torry?..cheers.Brian
Because of the prefix, you'll find the RTA will require you to meet the emissions standards of the motor, as it is newer than the car.
That means you need to comply with ADR 27a, which was first introduced in July 1976, meaning you'll need the pollutio |
