Coul Commodorenut or some other late model fanatic let me know the original size of the VN V8 disc brakes, I am lookign at converting an FB to four wheel discs and thought I might upgrade to std VN V8 stuff I have been told the rears were 279 x 10.5 could tis be verified. and I assume they would be running the 1 inch master cylinder as well for this set up? Cheers Matt
FJ Sedan, EK Wagon, TJ3 Bedford, C3 Bedford, it is more than a hobby it is an obsession!!! |
1962 EK Wagon - Chev SBC & T700, 1962 EK Sedan - Chev SBC & T700,EK Ute - V6 Buick & 5 speed = LOOKING FOR A 1962 EK VAN |
VNV8 front 290mm vented rear 280mm solid 1" master
Be careful not to cop a VN or VP V6 front rotor - they are 271mm (except for VP2, and FE2 cars)
You are spot on with the rears. You'll find a lot of catalogs will round up the rears from 279 to 280, and the V8 fronts from 289 to 290mm.
Make sure yo |
Thanks a million that is exactly what I was after, and more! Matt
I know this is thread stealing but anyway.
Will VN front discs bolt on to a VH.
James
You only have to be in front at the end of the race. |
Yes, the 289mm rotors used on VL Turbo, VL-VN-VP-VQ V8, and VP2 V6 will go straight onto the VH stub.
You need to team it up with the matching finned caliper as I described above.
VR/VS front calipers are everywhere, and the last 3-4 pairs I've boug |
