hainzy Offline
#1 Posted : Wednesday, 17 January 2007 11:43:34 PM(UTC)
hainzy
I have an original HZ sandman as a 'work in progress' in the shed, which has no gearbox (originally 253 and trimatic), I also have a HJ Stato in bits which has a turbo 400... So my question is, do you think I should use the t400, or am i better off being original and sticking with the trimatic? Which one is better do you think?
hainzy Offline
#2 Posted : Wednesday, 17 January 2007 11:51:45 PM(UTC)
hainzy
Oh yeah, and by the way, by which diff, I meant which gearbox.... me stupido!
#3 Posted : Thursday, 18 January 2007 4:04:52 AM(UTC)
Why not? Just shorten the sedan crossmember. Rest should all bolt in, including the tailshaft. Only difference is where the TH400 speedo cable exits the firewall - have a look at the HJ statesman and you'll see what I mean. You'll need to run a 308 with C
hainzy Offline
#4 Posted : Thursday, 18 January 2007 7:43:45 AM(UTC)
hainzy
Thanx Byron.
Is the crossmember on a sedan wider than a van? (Still tryin to seperate the extractors from the exhaust so I can get it out)A nd by chev pattern do you mean turbo? Ive already nabbed the power steering and most of the air con. Havin trouble
#5 Posted : Thursday, 18 January 2007 5:07:52 PM(UTC)
Yes. Just cut about an inch off both ends, redrill the holes and tack weld on some captive nuts. Turbo pattern is Chev pattern. You need to tranfer all of the air over a bit at a time, starting with removing your dash and glovebox from the van. There are
