#1 Posted : Tuesday, 24 June 2008 2:01:04 AM(UTC)
Hi all, In what may well be my last anon. post I would like to ask about the 173 red motor. I know bore/stroke, is the cylinder head the same as other red heads?
Where can I buy bits such as pistons/rods?
Were they a "good" engine?
Cheers and thanks
#2 Posted : Tuesday, 24 June 2008 3:06:00 AM(UTC)
Was thanked: 502 time(s) in 479 post(s)
There are basically 2 x red cylinder heads, and 2 x blue heads, with some minor variations along the way as pollution equipment appeared. The main difference is one has a closed chamber for the high comp engine and one is a 202/3.3 head for the low comp v
#3 Posted : Tuesday, 24 June 2008 3:16:37 AM(UTC)
Thanks Byron.
Is there any truth to a 173 and 186 block sharing castings? Could the 173 be bored to 186 spec if this is the case?
#4 Posted : Tuesday, 24 June 2008 3:34:01 AM(UTC)
I doubt it. That is a 185 thou overbore. They are not the same casting. If you want a 186 just buy a block. They are still pretty cheap, but in my opinion an inferior engine to a 202 especially one with a blue/black crank in it. Usage dependant of course.
bazza30555 Offline
#5 Posted : Tuesday, 24 June 2008 5:05:25 AM(UTC)
bazza30555
Whats a NF block Byron, can't see it on your site.
bazza30555 Offline
#6 Posted : Tuesday, 24 June 2008 5:05:25 AM(UTC)
bazza30555
Whats a NF block Byron, cant see it on your site.
#7 Posted : Tuesday, 24 June 2008 5:28:14 AM(UTC)
Website is awaiting an update. It's a Nasco replacement motor for a late LC GTR. May never have existed, but could have.
#8 Posted : Tuesday, 24 June 2008 5:28:14 AM(UTC)
Website is awaiting an update. Its a Nasco replacement motor for a late LC GTR. May never have existed, but could have.
David Offline
#9 Posted : Tuesday, 24 June 2008 5:28:47 AM(UTC)
David
And Byron, while you are at the comnputer, what might I pay for a 173s in reasonable condition or suitable for a rebuild?
Possibly my question is largely academic because I think there may no longer be any 173s come up for sale. The people who have the
#10 Posted : Tuesday, 24 June 2008 5:45:28 AM(UTC)
I actually have one sitting here, hence my interest. It is not something required for any resto job, I would actually prefer a 202 in standard bore config.
#11 Posted : Tuesday, 24 June 2008 6:19:12 AM(UTC)
Not sure. $1000?? to right buyer.
#12 Posted : Tuesday, 24 June 2008 6:32:35 AM(UTC)
I should clarify my 173 is probably an unspectacular version of said engine. I did not notice the little "s" in davids's post.
Sorry for any confusion or undue excitement this may have caused.
#13 Posted : Tuesday, 24 June 2008 6:32:35 AM(UTC)
I should clarify my 173 is probably an unspectacular version of said engine. I did not notice the little "s" in davidss post.
David Offline
#14 Posted : Tuesday, 24 June 2008 7:50:59 AM(UTC)
David
Hi Phill,
You did get me a bit excited for a moment. I must start using upper case S.
The 173S motor has an engine number starting CF. I suspect the NF motor Byron mentioned is the Holden replacement 173S motor.
Im not in a position to pay $1000
David Offline
#15 Posted : Tuesday, 24 June 2008 7:50:59 AM(UTC)
David
Hi Phill,
I'm not in a position to pay $1000
FastEHHolden Offline
#16 Posted : Tuesday, 24 June 2008 7:51:58 AM(UTC)
FastEHHolden
I used to think holden reds were a dime a dozen...until you need one and you have chucked them all out. No doubt you can still come across cheap ones...but its not an every day occurance anymore and I sort of disagree about your list...whilst those ones a
#17 Posted : Tuesday, 24 June 2008 5:44:21 PM(UTC)
I forgot about the HL. I still see red 6's going in the bin every time I'm at a wreckers, normally 173 or 202 though. Same for blue and black VL and VK prefixed engines. Of course any Holden 6 is worth money to someone who wants it. If say a bare basic 17
#18 Posted : Tuesday, 24 June 2008 5:44:21 PM(UTC)
I forgot about the HL. I still see red 6s going in the bin every time Im at a wreckers, normally 173 or 202 though. Same for blue and black VL and VK prefixed engines. Of course any Holden 6 is worth money to someone who wants it. If say a bare basic 179
This page was generated in 0.107 seconds.
