#1 Posted : Saturday, 31 July 2004 3:41:43 AM(UTC)
I have an LX torana(sunbird)that a fella want's me to change from a 4 cyl starfire to a 202.Will a holden 6 drop straight in or are the mount locations different on the 4 cyl front end,i've been told they are but aren't sure.Thanks
#2 Posted : Sunday, 1 August 2004 5:04:46 PM(UTC)
Hi Carl.
If this car is an LX Sunbird it will have an Opel 1900 4 Cyl not a Starfire. Starfires weren't fitted until partway thru the UC series in 1978.
Opel engines are painted black & have the carby on the RH (Driver's) side of the motor
#3 Posted : Monday, 2 August 2004 1:06:54 AM(UTC)
Thanks Dr Terry.Turns out it's a UC with the Starfire engine so it looks like a six will bolt straight in.He initially told me it was a 77 sunbird and i remembered someone mentioning once that indeed the front end needed changing if it were a 4 but i didn
#4 Posted : Monday, 2 August 2004 4:04:35 AM(UTC)
You'll also need a 6cyl tailshaft and to move the gearbox rearwards, meaning a new hole in the floor. The 3.9:1 diff will piss you off after a while too
