#1 Posted : Friday, 8 October 2004 3:49:41 AM(UTC)
Hi Guys,
I have a 96 VS V6, with only 190,000k's on the clock. Yet it uses about 1 litre of oil per 1000k's.
I have heard that it could be the ring gap, and been like it since it was new. Or the Valve stem seals... Any ideas?? I dont want to get ripped blind by a mechanic telling me lies, so i want to go in armed with the facts.
has anyone come across this before and what is the fix??
#2 Posted : Tuesday, 19 October 2004 2:50:25 AM(UTC)
Could well be your oil rings or valve stem seals. Suggestion have a compression test done by a Mechanic, and have him write down the compression to each cylinder.
If the compression is less than about 120 PSI you have problems as stated above.
Also try
