4 Pages<1234>
benny Offline
#41 Posted : Wednesday, 6 January 2016 3:11:06 PM(UTC)
benny
ok thanks , I will get a torch and my glasses and go and check the numbers and make sure they are correct, the engine didn't come with the car, I bought it separately, thanks again..
Edited by user Wednesday, 6 January 2016 3:12:28 PM(UTC)  | Reason: Not specified
benny Offline
#42 Posted : Wednesday, 6 January 2016 4:09:33 PM(UTC)
benny
ok heres the numbers ,one of the numbers was wrong,thought the 5 was a 6..skinny tag reads 81837H 519141 says above number general motors holdens pty ltd .. large tag reads HK81837KR-00105-H5 trim 1173-12X paint 568-10846 ..says on top of plate general motors-holdens pty ltd then under that in letters a bit bigger body identification, then in smaller letters under that correspondence must bear these numbers.. down the bottom of large plate has made in Australia and in bottom right corner lion holden emblem with holden written in tiny plaque under it. all the numbers are nice and crisp and are all perfectly stamped at exactly the same depth,looking from the back of the plates..the numbers on the skinny plate are set at a very slight height difference after the H and starting with the 5 being a little bit higher..thankyou for your time.
#43 Posted : Wednesday, 6 January 2016 5:05:12 PM(UTC)
The problem is H519141 is from late 4/68 so cannot be on the same VIN tag as 81837K. I own 81837KR-00002-H5 and its PSN is close to H530000 - it was assembled in the early days of July 1968. The 1st Pagewood GTS327 was red and will be close to mine. Also the K is missing from the numbers.
The problem with 81837KR-00105-H5 is the timeframe for this is around 8/68 but the paint line code is invalid for this timeframe. Plus compounding this 1173-12X wasn't an available combination, on its own not a deal breaker but with the other errors and mismatching the scent of a rat starts to appear.
The chassis number on the firewall may timeframe match one of these tags but I doubt it. You'd want to go looking for all GTS327 body evidence too.
Always be aware of perfectly stamped numbers on GMH tags too. There are a lot of faked tags around.
benny Offline
#44 Posted : Wednesday, 6 January 2016 6:13:27 PM(UTC)
benny
did they ever make mistakes when stamping these plates, maybe the 1 is supposed to be a 4 or a 7,??? it would be good if I could find a Sydney car close to the 105 build to compare plates with..thankyou .
#45 Posted : Wednesday, 6 January 2016 7:49:26 PM(UTC)
GMH Production didn't stamp the PSN part of the VIN plate, it was purposely pre-stamped to avoid errors. Pagewood 105 would be many 10000's away in PSN. The wrong paint line used for Warwick on the body tag for the timeframe of this car is normally another dead giveaway to a faked tag - the good thing is the tag fakers don't know all the info they need to. You'll probably also find inbuilt errors in the body tag if it is a faked one, the people who did these in the USA did this on purpose I think.
benny Offline
#46 Posted : Wednesday, 6 January 2016 8:17:33 PM(UTC)
benny
what can I say, I am shattered by this news,have been chasing up parts for this car for years,thanks for your help in clearing it up..i will concentrate on the other car now which is an Adelaide build.thanks again .
detective Offline
#47 Posted : Wednesday, 6 January 2016 8:31:28 PM(UTC)
detective
...should these tags state "General Motors Holdens LTD, or otherwise "General Motors Holdens PTY LTD ?
#48 Posted : Thursday, 7 January 2016 6:03:33 AM(UTC)
Both, except LTD is LIMITED on the first one mentioned. It changes during the 70's.
#49 Posted : Thursday, 7 January 2016 12:20:23 PM(UTC)
Was thanked: 27 time(s) in 26 post(s)
Its is really disturbing the number of cars like this that are turning up. Image how many there are out there that are not known.
Warren
#50 Posted : Thursday, 7 January 2016 12:48:01 PM(UTC)
I asked Ben about the Mosman Park and V8 HK thing. He reckons there are a few hundred of them, he has engine numbers up into the 30790200's. Mosman Park did assemble some Monaros too apparently too - I was with you Warren, first I've heard of this. Some have come up though, Elizabeth built, Mosman Park assembled like the HK ute described in previous posts. Ben's take on 307P2951 is that if this is a mis-representation of the original engine number for a Mosman Park HK ute chassis number HK43924AP optioned with a 5litre engine, it has to be 30790295 or something like that. It is also possibly a jumbled mess of the GMH stamping and the McKinnon Industries stamping after an engine decking, the original number would have been something like 30790295K0713 given the timing of the Elizabeth body.
FE327CHEVY Offline
#51 Posted : Tuesday, 12 January 2016 11:14:57 AM(UTC)
FE327CHEVY
Sorry fellas, been away. It will be useful useless info Eh? to me to know if all the numbers being close together at the top of the block indicates that its a Flint block, making it more likely to be a truck engine and not a Parissien replacement six engine.
#52 Posted : Tuesday, 12 January 2016 1:15:59 PM(UTC)
It isn't a McKinnon casting with the date code there, my guess is almost certainly Tonawanda. Very odd that you have a Tonawanda cast 327 with a McKinnon engine number.
Looks like it may actually be a Flint block, appears to have a little tapped plug in the front of the block just to the right of the engine number.
Edited by user Tuesday, 12 January 2016 1:34:55 PM(UTC)  | Reason: Not specified
FE327CHEVY Offline
#53 Posted : Wednesday, 13 January 2016 6:26:39 PM(UTC)
FE327CHEVY
Thanks mate. I am satisfied that it's a truck engine due to blue rocker covers, Flint block, double springs and rotators, etc. Can't wait to get your answer.
detective Offline
#54 Posted : Wednesday, 13 January 2016 9:02:48 PM(UTC)
detective
...Jeeez mate .. after about three pages....I think we all might've forgot the question !! LOL
gm5735 Offline
#55 Posted : Wednesday, 13 January 2016 10:29:16 PM(UTC)
gm5735
I believe the 3903352 was only ever cast at Tonawanda. That doesn't preclude it being machined elsewhere however - not common, but not unheard of.
#56 Posted : Thursday, 14 January 2016 5:56:07 AM(UTC)
It may be Tonawanda, just the little oil gallery plug at the front just below the filler tube made me think it was possibly a Flint block, but it may also be a truck thing.
In 1967-1968 there does seem to be specific castings at Saginaw, Tonawanda and McKinnon and in the 1969 rationalization they all seem to become common.
Rusty HQ Offline
#57 Posted : Wednesday, 3 February 2016 6:47:35 PM(UTC)
Rusty HQ
Sorry for the delay. Here's the photo's I could find of my 327 out of my RHD '67 Impala. Can't find the shots of the side casting numbers.
Block:
Heads:
#58 Posted : Wednesday, 3 February 2016 7:27:05 PM(UTC)
This one is essentially identical to the earlier one from the thread of FE327CHEVY's:
Tonawanda 352 block assembled by McKinnon Industries.
Canadian 482 heads.
A 5 digit number in the same font preceding the engine assembly code.
Any photos of the intake manifold?
This definitely came from a GMH assembled 1967 Impala? If so I reckon FE327CHEVY's also came from a 1967 Impala or Parisienne.
Do you know which GMH assembly plant assembled the car?
Edited by user Wednesday, 3 February 2016 7:28:47 PM(UTC)  | Reason: Not specified
gm5735 Offline
#59 Posted : Thursday, 4 February 2016 12:11:38 AM(UTC)
gm5735
That tallies with what I understood about the 3903352 block - Tonawanda only.
I thought McKinnon was well and truly up and running with 327 casting by then.
Why would they get blocks from Tonawanda, I wonder?
#60 Posted : Thursday, 4 February 2016 6:17:41 AM(UTC)
According to the info I have McKinnon didn't tool for 327 until 1966 and 307 in 1967. It doesn't say when in these years they started casting and machining either though, but I know the 307's were being cast and machined at McKinnon by 9/67 as I have plenty of early HK 307's cast and machined in September 1967. It is possible these are close to the last of their kind.
Those 3814482 heads are 75cc heads, which means the 1967 engines were about 8.55:1. So now we have plausible explanations for the 4BL low comp 327's power increases:
1966 was 230hp.
1967 was 240hp, increase due to the new Quadrajet.
1968 was 250hp, increase due to the compression ratio hike from just over 8.5:1 to just over 9:1.
It does appear that there were different casting numbers used between the US casting plants (Saginaw and Tonawanda) and the Canadian McKinnon plant up until 1969 when manufacturing was restructured. This is probably why the 3917290 head of the Tonawanda 1968 HK 327 head is a different casting number to the McKinnon HK 307's 3911032 although the heads are identical. Same for the HT manual 350 engines, they got 3947041 heads which look to be the exact equivalent of 3927186 heads, and Tonawanda 3947040 heads are the direct equivalent of Saginaw 3917291.
4 Pages<1234>
This page was generated in 0.093 seconds.
